Section "View Name" per sheet or per project option
Hi there,
I would like to submit a request on Revit improvement, forgive me if this has been already suggested!
My request is for Section View Name. In my experience, naming sections usually are by project or by sheet.
For instances:
1) When I have floor plans I would create sections (project based) meaning that section will cut through all the floors thereby it will keep the name identical (as currently is available in Revit);
2) On the other hand, in case of detailing an element (Ex. isolated foundations), we usually have two sections views for each, then I would rather have my sections View Names reset per sheet.
Would love to hear from you guys if there is a solution available already!!!
Thanks!
0
votos
