Tag rebar cover
It would be great if i could tag the cover in different structural elements such as Wall, Beam, Column etc.
I mean a cover-tag that can be applied to all elements which can contain rebar.
By the way a beam (we use a wall with function set to foundation) must have more settings in the covers, see pics.
We use walls because we have usually more foundation beams without a wall upon it, and it is way more flexible.
Tag element for coverTag element for coverThnxs.ideal different cover valuesideal different cover values
