More accurate message about the corruped link than is currently provided
In one of the support cases the user had a problem with opening the central model from BIM 360 Docs. The problem was a corrupted link. The error message was as follows:
"A serious error has occurred. It is strongly recommended that you use Save As
to save your work in a new file before continuing."
Then clicking on Save File And Continue will gives another warning:
"Load cancelled"
I think it would be better if, when opening the model, there was information which link exactly is corrupted. In the journal file, the GUID models appear so we have a starting point. In this case the model had only 2 links. But when the project contains of tens or even hundreds of links the problem is much bigger. I believe it will be possible to achieve this and implement it into Revit in the future.
Comentarios
A Thumbnail to the view, marking what is lost, will help?
Vote for this.
https://forums.autodesk.com/t5/revit-ideas/thumbnail-when-error-messages-appears/idi-p/9766554
