Insert NWC Coordination Models in Revit via BIM 360 Glue
It is currently possible to add NWC files in Revit with the "Coordination Model" tool :
It would be perfect if we could add NWC files directly from Glue !
This way, we could have the last updated models in Revit from all the collaborators and still have the advantage of the lightness of the NWC files !
The new tool could be added as an option in the "Coordination Model" tool or in the add-in BIM 360 which allows to export to Glue:
Thank you
Étienne Royer
Comentarios
And also from BIM 360 Docs.
Currently when you link to nwc that is on 360 Docs you will have your username in the Filepath, that is not very useful on a workshared model.
El estado se ha cambiado a: Accepted
El estado se ha cambiado a: Implemented
We are pleased to say that this has been implemented in Revit 2024! Thank you for your contribution to improving Revit!
Help | Link Coordination Models | Autodesk
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-2D77DCD8-A4C7-48F7-995F-237693350747
