Naming of section BEFORE drawing it
When drawing a section you have no possible way of naming that section when drawing it.
Generally (for me anyhoo), i use filters to remove all other sections others have drawn, so
the section i just draw, diseappers and you need to turn on the filter, and in some cases, the section can be hard to find.
Idea: Possibility to name the section before drawing it.
Best regards
Comentarios
I agree it would be helpful to draw a section with some properties already changed, but when you draw a section  the properties palate will show the properties of the new section until you hit escape or click anywhere so you've got a chance to name it without turning on/off the filter.
