Pipe Spacing Tolerance Indicator
This would be handy  to space piping with a tolerance from another object such as a wall or a opening in a slab. You should be able to align the pipe based off this tolerance indicator against a wall or align an object such as a wall  against the pipe spacing tolerance indicator. The end function of this would allow you to quickly position a pipe and avoid potential clashes down the road. This value for the spacing tolerance indicator can be set under Pipe mechanical settings
