Sorting filters in Visibility/Graphic Overrides by name
When we are using Revit MEP, we have to use a lot of filters, because we have so many piping systems.
And our problem is, that we cant sort the filters, is it possible to enable a sorting metod for the filters for next update?
Comentarios
Sort by name is not compatible with the usage of the order in this filters list.
The order in the list means priority of the filters. Order by name will be difficult for apply in the panel.
Revit Help : "You can apply multiple filters to the same view. The order in which they are listed on the Filter tab of the Visibility/Graphic Overrides dialog determines priority. The filter at the top of the list takes precedence."
https://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-FA7B0AD9-4F0F-4405-9DF7-35D30D7CBE7B
No, we dont prioritize our filters, because if we are 10 colleges on the same project, it is very difficult to now which filter over rules another, so we have one filter for each piping system, and then we can turn of each system, because we have around 60 piping systems.
