Placing Conduit in 3D
In a 3D view, once the start point is established to allow a rotation of planes to go from XY to XZ to YZ and then back to XY after a press of a command before placing an end point to the conduit. If the planes could even be adjusted to run parallel/perpendicular with a started snap point on an existing conduit that could resolve issues with plane rotations, or incorporate the work plan command to give a starting plane. Once the end point is placed then placing conduit can reset back to the XY plane. The ability to change the rotating plane command would be nice, my idea would be to use the space bar to rotate the planes. It is frustrating and time wasting to place a conduit and change one end's elevation, or snap to an offset elevated conduit. The set work plane is a great idea, but does not work for what I need it to do when placing conduit in the Z coordinate.
