@Anonymous: That's kinda difficult to do. Different parameters may report different numeric values, but combining "black sheeps" with "white goats' may result in false results based on false assumptions. You should try doing so in Dynamo and see if it works (whatever your particular idea may be).
What i mean is simple math ops (addition, multiplication, etc) does not always reflect technological ops and technical stages.
