Break Line button next to Insulation button
We need a Break-line button next to the Insulation button on Detail panel in the Annotate menu. Insulation and Break Line are the most used Detail elements. It's counter intuitive to search for a Break-Line, load it in a project (Insert menu>Load Family>Country_Name>Detail Items>General>M_Break Line), then use the Detail Component button in insert it in a view. Way to many clicks and menus to use.
P.S. I know the Break Line is a composite component (Lines + Masking region), yet i believe Revit interface should match modeling and drawing workflows, presenting shortcuts (buttons) for the most used elements.
