Z Justification for Floors
It would be useful to be able to have the option to change the Z-Justification of a Floor Slab (i.e. to be able to set the Constraint Level to Top or Bottom) . This is particularly important for elements such as elevator over-run slabs, where it's the underside of floor that is the important dimension. If the floor gets thicker, it always extends downwards.
Comentarios
