Ability to display pipes in a plan region in Revit
Based on my research, I have found that pipes do no display in plan region in Revit. Attached is are some images of the pipe visibility in section. The visibility of the pipe in question is circled in red.
This should be fixed so that we do not have to draw in detail lines in the ceiling plan to indicate the pipes.
Aarti Gandhi
