Add the option to use fabrication pats when creating families. Instead of making something that looks like a flange, I would like to pull a flange out of existing .ITM database and attach it to a family.
I'd more like to see it go the other direction (both ideally), take a Family and wrap an ITM around it and export the Family's Parameters as Dims/Options in the ITM. Much like you can take a CAD Block and Create3d or WrapIt in CADmep.
