Centroid
Pretty plain and simple.
Centroid extraction of Revit elements (applicable to Generic models and such)
Asked for in forums (problems) since 2012..
Dynamo as a coding language is too buggy, it requires a perfect set of solids, it is rather impossible in most cases because sometimes these intersect a lot.
If AutoCAD can do it it is unbeliveable Revit can't. AutoCAD has too many steps in getting the results and doesn't include density (mass=volume).
GRAITEC offers this but their support is bad, and 700 euros per year only for centroid function just because Dynamo is a weird perfectionist... no thank you. Same goes with Inventor which is not even a part of AEC.
Think about this guysssss... think about it.
Comentarios
I happen to need this functionality too, but I found two ways to get a centroid in the Revit API.
Autodesk.Revit.DB.Solid has a ComputeCentroid method.
Autodesk.Revit.DB.Analysis.PolyLoop has a Centroid property.
Hopefully one of these methods work for you.  I will be trying them out myself shortly.
El estado se ha cambiado a: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community (votes or comments) over the last 24 months. Please feel free to re-word (titles and clear descriptions for specific features or enhancements are very important) and resubmit this Idea.
