Default of roof slope when in the roof footprint command.
Suggestions to default settings:
  1. when starting a roof plan change default to no slope
  2. When setting a given roof edge to activate a slope, change default roof slope to 4/12 not 9/12.  9/12 is a very rare roof slope.
Comentarios
I would prefer that we have the option to set the slope in advance. Right now, it defaults to the value in the template (9:12), but we typically have a lot of slopes (and almost never 9:12). That negates the option of updating the template.
You can uncheck the Defines Slope box before placing the sketch lines, but when you select the lines you want to have define the slope, you can't change the setting until after they are picked. I would like the option to set a slope and then select the lines. Then I can change the slope and pick new lines. No editing required.
