Fabrication Parts mismatched connector workflow
The connector mismatch feature added in 2019.2 works for a piping workflow. i.e The pipe is modified when attaching a fitting such as a grooved fitting, the program will change the pipe to a grooved connector.
In sheet metal fabrication there is often a need to override the connector on the fitting, not the pipe. The only way to do this now is to edit the part manually. When the mismatch connector dialogue comes up it would be nice to have an option to edit that part at that time, the current workflow would force you to delete the element and start over remembering to override the connector before connecting.
The ultimate goal would be to add intelligence to the parts/connectors to automate this decision.
