API IndependentTag.Create() is slow
When using IndependentTag.Create() from the API, the process for each run of this command takes much longer than it should have to (on a large model it's taking 20-30 seconds per tag). This impacts our workflows and time spent doing a relatively simple process. This API function worked seamlessly in Revit 2016 and below, but something changed in the code that negatively impacted it.
Comentarios
This still is the case... I notice it too. I want to add tags of ~1000 walls to ~3 views and I can't afford to wait for ~16 hours to complete the script.
It regenerates the graphics for every tag...
BTW: I like the fact that the text "Add tags" below your post is the title of your post as well as a function of this forum.
This is still the case entering last quarter of 2022.  No matter how i try to set it up with loops and transactions this process takes insanely long time. I can't seem to find another way of creating a tag through the API.
Just came across this issue as well. In my case, activating the owner view before creating the tags seems to solve the problem.
