Rotate a single mullion (curtain wall grid)
It should be possible to rotate a single selected mullion (or rather curtain wall grid)
Example of problem:
All mullions need to be horisontal except three that are tilted for different reasons.
Comentarios
I'm looking for a similar solution - is there a way to rotate a single curtain grid line?  Revit appears to let you rotate a single curtain grid, but fails to actually rotate.
Any work arounds for this if not possible?
I have the same question but no answer.
Still no answer?
No way to do a simple flip of a V mullion etc.?
