Which "building code" are you referring to? Revit is used around the world and building a tool to adhere to one standard for one country would only cause issues for every other country that uses a different code standard.
Instead, the tool has been built as an analysis tool, not a code tool, with an API that will allow customization to meet the many needs of various codes worldwide.
