Change Parameters used for the Panel Schedule Update Names tool
The Panel Schedule Update names tool by default pulls in Load Classification, Space Name, Space Number as a combined parameter. Problems are:
1) does not handle multi spaces well. IE: the spaces numbers all show up but "Room" is placed before the first one and that's all. We would like to see it say Space Name1 Space Number1, Space Name2 Space Number2. Not "Room" Number1, Number2
2) the fact it pulls load classification as the start of the parameter is nice until you get to the load classification part of the schedule. If you want more descriptive names in the Circuit Descriptions you need to create tons of Load Classifications thus blowing up the schedule size.
3) regardless of change it would be nice to still have typing ability in the schedule regardless of which parameters are used to create the Circuit Description. If you switch to a combined parameter you can't edit it in the schedule.
The ability to control how it displays multi space information and which parameter it pulls for Load Classification would be nice
