Revit Spaces New Parameter: [Actual (Heating/Cooling) Power]
Hello all,
I want to suggest adding two parameters for Spaces in Revit:
- Actual Heating Power -(Tatsächliche Heizleistung).
- Actual Cooling Power (Tatsächliche Kühlleistung).
These parameters are to calculate the sum of the Heating/Cooling power placed by Revit Families within a Revit Space.
It is in a way similar to the parameters [Actual Supply Airflow, Actual Return Airflow, Actual Power Load, etc.].
I hope that this idea will be put on the roadmap soon.
Your support fo the idea is appreciated!
Thanks all.
