Render Path & Custom Image Library
The method of adding custom render image path libraries is incredibly clunky.
Whilst we are in the age of metadata it'd be nice to think we would all be using one searchable folder for our render images, but that is most usually not the case, with render material images libraries often spread across a number of folders to make it easier to find what you want.
As such it pretty awkward to have to add every folder to the alternative render path directory in Revit options.
Please, please can this be made easier. At the least it'd be nice to add just the main library path and have all it's sub folders automatically checked.
Also, please can the Revit standard materials images path be included by default in the folders list? It's not exactly in an easy to find location!
