threshold for silhouettes graphic display
It would be useful to have a threshold for what Revit thinks is a silhouette, the display mode only really works for simple massing, but any detailed model will give you a silhouette on any old edge, mullions, balustrades etc... which defeats the purpose in my opinion.
Would be great to somehow be able to just get outlines for major edges, or a dial like the depth queuing.
Comentarios
I agree.  This has been suggested before but lacked support.    Let's keep trying.   The lineweight of an edge in elevation should be a calculation, depending mainly upon a change in distance from the elevation plane.  Currently, a change in distance of only 1" looks the same as a change of 50 feet.  Likewise, there is linework density to consider, which is your point about balustrades.  If the tool doesn't have even a basic correspondence to good drafting conventions, I can't use it.
