Footing Schedule-thickness shared parameter
There is a previous post regarding how to work around the OTB rectangular footing family not scheduling the thickness.
This is a really easy fix for the next release of Revit. Change the existing parameter in the family to be shared.
Its been broken since I started using revit in RS4. Its never been fixed (as of Revit 2015). As such, the OTB family is never used.
5 minutes and any revit user on autodesks staff could fix it.
Cheers
Comentarios
@SeanSpence, thanks for bringing this to my attention. I've filed a defect in the Revit development team's database and the team is reviewing the correct way of doing this.
In response, this request has been addressed in the Revit 2017. Please check it out.
More information available here: Revit 2017 Help page
regards
Pawel Piechnik
AWSOME!!!
I was starting to loose faith in the idea station.
Thank you @pawelpiechnik  on behalf of all structural Reviteers!
El estado se ha cambiado a: Implemented
 @cindy_wang @pawelpiechnik
This is NOT fixed yet!  I have Revit 2017 and it is absolutely not default parameter.
Hi there! im just here to tell you im using revit 2020 and still does not have this. Says "Fundation Thickness" but appears blank when you schedule. Thanks
El estado se ha cambiado a: Gathering Support
@Tarek_K again, this has been implemented. why is it going back to gathering support?
