Corruption after updating the Revit 2017 to Revit 2020.
After upgrading the file from Revit 2017 to Revit 2020, and further using the command it showed up error "Serious error has occured........". Further reviewing the file it showed that some elements where gone corrupt on which deleted the error did not showed up. I will request to produce the Hot fix for the same.
Comentarios
Did you update all at once? Directly to 2020?
When updating across several versions, it is advised to do this version per version.
2017-> 2018->2019 ->2020
Audit the file each time you update, this should minimise errors.
El estado se ha cambiado a: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community (votes or comments) over the last 24 months. Please feel free to re-word (titles and clear descriptions for specific features or enhancements are very important) and resubmit this Idea.
