Renovation tool for objects
If you want to renovation current window/door with new window/door (just window, not opening) is little bit hard at this moment. You change your current window phase to demolished, Revit fills the opening and after that you try to fit the new exactly same window to filled opening.
Is it possible to make tool like "renovate object" which makes the same thing with a push of a button. It would be a lot like on Massing&Site Graded region makes to topography.
This would be very helpful tool for all renovation projects
