Schedule should not be active upon opening
When you open a schedule, Revit should not place you in the first cell, or in any cell.  I can't count the number of times I've replaced a cell value with "wt" because I wanted to tile windows after opening a schedule. This is super annoying worse, important information can get overwritten.
Comentarios
Also, schedules should not open maximized by default.  There is no reason for this and it adds mouse clicks.
@PDSF I second both your ideas.  I remember the first time the firm principal asked me why the door number column was called weight.  "wt"
