Linework Tool and Design Options
I would like the linework tool to work on any line selected, whether in main model or design option, without having to change between the two. If I need to hide the joint between the main model and an option, I obviously want to change both lines, and switching between options wastes a lot of time.
Of course, even better would be if everything cleaned up correctly, whether the option is primary or not.
