Display useful measurements
When placing stairs there are few measurements that users really care about, one is the distance from the top and bottom stair to the next nearest object; you know, like a wall. Stairs would be useless if the top step dead ends into a wall at the top or bottom; there is also that small thing called code that must be um complied with.
How about Revit automatically display the distances that are useful to designers like the distance from the bottom step to the wall that might otherwise be in a person's way of using the stairs!
