minor text changes inside property window
Little adjustments to model texts should also be feasable on the top layer of the property window. Ie. if you edit a model text from 'CAUTION' to 'ATTENTION', Revit will open another window with the text editor while editing inside the pp window would suffice. Would save us a lot of clicking 'OK' to finish editing.
