Allow Keyboard Shortcut for "Go To View"
I'd like to be able to assign a keyboard shortcut (such as "GV") to Go To View, instead of right clicking on the view reference and finding the button with the mouse every time. Would be much faster to just click the section and type "GV".
As it is, Go To View isn't an option in the keyboard shortcuts dialog:
Comentarios
Any changes in the status of Revit's capability to add a shortcut for "Go To View"?
I select the section , right click, Type "g" on the keyboard as a nice workaround.
er.. I usually just double-click the section head, callout head, or the elevation marker of the view I want to see..
or is there something else I'm not understanding? I do get it that sometimes there are a bunch of section heads clustered in a WIP view..  and then finding the right section head to double-click.. but that's my only doneside tho..
Observer
Observer
@jasonEES8F i came across your comment - thanks a lot :-). I had no idea it worked with just hitting 'g'.
@MahdiSalie thank you as well :cara_con_una_leve_sonrisa: i was so frustrated, as double clicking on the section does nothing - but offcourse the section head works :D.
Cheers
