Crop region to be invisible on sheet but active in the view
I need a functionality in Revit -properties for crop region to have a check box that says ‘hide crop view when view not active’, so when you’re in the view working on it, you can adjust the crop boundary, but when you’re on a sheet without views activated you don’t see the frames. Reason for this wish.As the lines for the frames just appear like normal linework, it is difficult to distinguish between a frame and linework sometimes and it just means the sheet view doesn’t look exactly like what the print is going to look like.This saves a lot of time and true to the saying of Revit "what I see is what I get in the print"
