Add Worksets to Transfer Project Standards List
If you have a host model and you want to control visibility of worksets from linked models, one way is to create an identical workset in the host model. If the worksets are named exactly the same in the host and linked model, your Visibility Graphics will control both.
However, now you have to manually create those worksets and make sure you've named them EXACTLY the same. When you want to do this for a lot of worksets, it would be great to have worksets as an option in the Transfer Project Standards to get them instantly in the host model.
