disallow join symbol
please add disallow join symbol to elements such as beams and walls, instead of having to right click on the tiny blue grip and select disallow join. At times it is impossible to right click on the grip and it would be a lot handier. Especially vertical bracing is impossible to have joint to other framing unless all elemetns are of same size.
It could work same way as the "allow join" symbol.
Comentarios
I would appreciate it, if join could also be disallowed for good inside a project or a revit installation.
