Title block tags to dwg attributes export.
We really need to be able to export 'intelligent' titleblocks from Revit to dwg where Title block tags are mapped to dwg titleblock attributes. I can't believe that this is not already part of the export process?! PLEASE add this feature, it causes huge amounts unnecessary work to achieve this simple task before we can deliver dwg files that are up to par!
Comentarios
I second this.....This is a huge deal....and needs to be worked out.
Yes, I have 3000 files coming over into DWG format from Revit files and need to catalog them in Autodesk Vault and make them searchable by title block attributes.
