Revit Ceiling, Complex ceiling modeling
Hi, Team,
Could we create a complex ceiling by using a similar way of creating roof.
We received this wish from one EP customer:
Currently, we can create a sloped ceiling:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Yet it is still too difficult when we need to create a ceiling for the Villa hobby, please see the attached images.
Could we create a ceiling by using a similar method of creating a Roof?
Thanks!!
Comentarios
As a workaround, we can define the ceiling system as an attachment to the roof system if they are parallel in spatial or have a straightforward relation ( define the air thickness as variable).
Advantage:
Adding ceiling to the Roof system
1 Section view is correct
2 Quantification is correct
3 Plan view is correct
4 The ceiling gridline can be shifted
