When ever an export is created from Revit to AutoCAD and you have images in the title block or on the drawing it sends out the image not only with the original file name, but also the project name-username-image name-random number. Could you program it so that when the image is exported out it only uses the image name? Working with many government clients and have been told repeatedly that file names are too long and then having to go into AutoCAD(gross) to re-path all the image files with the shorter name. Please help so we can stop using AutoCAD!
Example of current: 18013JBZDLA403-Arch_bmccoy77-IMAGENAME-6204745.jpg
Example of desired: IMAGENAME.jpg
