Sheet List Appearance Properties
Allow the Sheet List Header text properties to apply to Headers that are applied in the Sort/Grouping properties but the "Show Headers" at the top of the Sheet List is turned off.
Currently the "Headers" applied in the Sort/Group Properties utilize the same text as the Body Text.  If they are called Headers then it should use the  "Header Text" type!  This would allow the sheet list to look not as dull as they currently are and maybe allow headers to be a different size from the rest of the body like a true title should be.
Comentarios
OK, I was confused at first by what you meant, but now I see.  I had to look at the images you attached to the idea to understand what you were getting at!!  Two pictures in this case were definitely worth 2000 words.
To take this a step further, perhaps there needs to be a fourth category in the Appearance tab for Sort/Grouping Header appearance type.  Just a thought!!
