Enable/Disable Section Box from Temporary View Properties mode
It would be useful to be able to enable or disable section box from the temporary view properties mode. Currently if you're in the temp view properties mode you can edit a section box, but you can't turn it on or off. You have to restore view properties, enable/disable section box, then go back into temporary view properties mode, which is a little annoying.
Comentarios
and the same goes for scope box. When in temporary mode, the scope box is greyed out so you can`t switch it off or change it. Just make the "temporary View Properties " mode be able to edit everything.
