Would like to see Sheet Layout Templates.
Template sheets with view placeholders and other default settings (e.g. text , lines) might help to speed the process of creating sheets
Quite often we have to create many sheets with the same layout. For example we add a 3D, front, side and top view to the sheet. For every sheet we have to add the views and position them and preferable align them so that all sheets match.
If, for example, you would have a sheet template with four placeholders, then selecting four views would automatically place them on the placeholders. Then selecting the sheet would allow to fine tune the sheet layout were necessary.
