Default Print Settings
Please allow us to set default print settings per project. I mean this to apply to all settings within the print dialogue, including printer name, Combine Sheets, and everything under Settings/Setup. I'd like to see an "Apply to Project" button similar to AutoCAD's "Apply to Layout" button within its print dialogue.
I think Revit defaults to the computer's default printer (which I never want to use in Revit). I've seen some comments that the default settings are based on the template from which the project started. But hardly anyone uses actual template files because you can't have worksets and other necessary settings within them.
We need to be able to change print defaults on a per-project basis instead of having to reset everything every time we print.
Comentarios
Print Window button and Scale Lineweights (to paper size) from Autocad are CRITICAL too.
I use PrintScreen option in Windows, save the picture then crop it as needed. Snipping Tool does the same result. Because Revit can't. How stupid is that?
P.S. I just fail to understand how such old software like Autocad can Scale Lineweights to paper size and Revit can't. I always print partial drawing leaflets from Revit, and the lineweights are always wrong.
