Remove the sync from revit
Hi
What will it take for AutoDesk to completely remove the need to synchronize to a central file? Imagine if you needed to sync to get another players location when playing a computer game. That would be crazy right? Now imagine if everyone on a project in revit, just working and you could see walls move on the fly. Like a live version of the current way the central file system works.
Is this hard to do?
Thanks in advance
Comentarios
If networks were operating at tetrabyte speeds and you had a server that could accept multiple  write commands at once on multiple files...might be possible.  If the file properties were similar to OneNote possibly, but I think commands for that are queued as well, essentially doing the same as a central file.
