"Create similar" tweak for regions
Using the "create similar" right click on a region the "similar"does not necessarily keep the properties of the original with regard to fill patterns. Would be time saving if it did.
Also it would be nice with regions to click on a region and be able to change line styles/weights direct from an attributes box rather than select edit, select the lines, and then select a different line type. I know this would change all lines in the region but 99% of the regions I draw use the same line for the perimeter.
David
