Thickened Floor Slab
Please allow an easy solution to create a thickened slab.
For instance, I'm modeling a concrete floor, (Not Slab-On-Grade, but it could be) and I need to transition a 4" thick slab to a 6", or 6" to 8". If the slabs are flat, I can model one, then model the other and join them. That's too many steps, but it's not a big problem. If I have a sloped slab that needs to be thickened in some areas it's more difficult.
Please give us a pull down under the Floors tool for "Thickened Slab" that allows us to sketch an area that is thickened for that slab. Similar to a Slab Edge or floor/wall opening.
Thank you for your consideration.
Comentarios
I would REALLY like to see there be a thickened slab wall foundation!
Additionally,
Apparently we can't add a slab edge to a sloped floor? We have to un-slope it, add the slab edge, then re-slope it?
Please create a thickened slab tool that works at interior conditions.   This isn't a one off thing that some people do sometimes on very special projects, its common practice, so there should be a tool for it.
Ideally this tool would allow me to place the thickened portion either freely anywhere on the slab, not necessarily attached to walls.  It should also integrate and blend nicely with the rest of the foundations in the model, specifically in plan view, not just the 3D view model (really everything should be focused to look clean on plan since thats the deliverable to the client).
I'm fully aware of the work around using the Slab Edge tool, but its a work around.  I can eat steak with just a fork, but I'd prefer to use a knife.  Having to do the work around every time wastes a lot of billable time and it always looks a little off in plan.
@mblevinsUM3XV  though not ideal see the following YouTube work arounds: Thickened Slabs under Walls in Revit 2020
This is very typical detail in a lot of construction project. I'd be lying if I said I was surprised that it isn't in the software already.  Is bit frustrating with the lack of actual tools just to produce simple geometrical details and schedules required by arch's, eng's and cad's in a cad software package, and what Autodesk actually gives us every year.
Suppose the simplest and easiest way to do this is to have 2 options available in addition to modifying a slab (current tool which doesn't resolve this requirement) (1) set level/offset above slab and (2) set level/offset below slab using points and lines in a sketch environment. Where you have 2 or more level changes you would select sketch lines/points and set a level on them. The reason for number point 1 is to allow for 2 scenarios.
scenario 1: the slab edge may be raised above the slab top face to a given measurement, thus creating a bit of a wall along the slab edge. The practical real world application this would be perhaps a chemical, petrochemical plant where they are required to contain spillage. In some applications they would cast this raised section at the same time as the sab.
scenario 2: To create a stepped raft foundation as can be seen in typical detail below. The level/offset control would need to allow for negative value i.e. -1234 where a portion may be below the main level of the slab.
This idea would solve quite a number of issues:
1. Beam method level misalignment seen in YT at 2:17
2. Slab edge method on a foundation creates extra work even if profile parametric as seen in YT at 12:02
3. Easily create openings in a slab. Currently slab edges don't allow cutting with an opening as seen in my idea here: Shaft Opening can cut Slab edges
4. More easily schedule data, as current methodologies require multiple schedules creating extra work to derive required data such as total volume.
5. Easier control of visibility graphics eliminating need to create filters ie creating a wall like mentioned above requires a filter to eliminate other wall types out of a view
