Story Above - Level properties
If the Level  "Story Above"  parameter could be used for more than defining IFC export settings, it would be great.
At the moment view range and objects just refer to the next level above. Even though the level above might belong to a nother part of the building.
Copying, creating similar and other functions would be much easier to use if every level knew what level was meant to be above it.
Comentarios
When I first found the Story Above function I automatically thought it was what you described only to find out it did nothing for my model. It is a necessary feature.
