Control the rotation angle
Hello Autodesk Team
We all know that with spacebar the elements are rotated, But only at a 90-degree angle or proportional to the angle of an element.
It's much better if you set the setting to control the rotation angle for the spacebar.
For example, in the Object Snap window add an Option for control angle spacebar.
