Mini-Autocad extension for Revit
A mini-Autocad extension for Revit would be very helpful. Let's face it: 2d detail lines are not very precise and not very easy tot use. Why reinvent 2D lines when you could incorporate Autocad into Revit (at least the basic commands), as an extension ?
Or make Autocad 360 run inside the Revit interface. Some professional-grade CAD tools in Revit would make the  Autocad users switch to Revit.
Comentarios
Posted a similar idea for Inventor over on AUGI
http://forums.augi.com/showthread.php?168338-AutoCAD-built-into-Inv-IDW
could be a common core feature for all Autodesk  products if they had common core team as a general idea I posted
https://forums.autodesk.com/t5/community-ideas/common-feature-core-team-page-for-autocad-revit-and-i...
