Ceilings and components of ceilings
In wall types components can be unlocked so you can drag things like gypsum board down from above ceilings allowing the studs to go to structure, etc.
Why can't this same option be unlocked with ceiling components? For instance, say you have a shower ceiling that is tile, why can't you stop the tile at the wall and unlock the sheathing board and studs and continue them over the top of a wall... this would be a nice option to have... If it can be done with walls in section why not ceilings.
