Tag doors and windows contained in a linked file
It would be good to uniquely tag each door and window containing inside a linked file, that is in turn, has multiple instances in a main file.
For example, if we have internal doors within a linked Revit file (apartment) which is used within another Revit file (building), it would be good to individually number each door to facilitate custom door hardware configurations on the schedule.  Yes, each Revit file instance is identical in planning, but each door can require different hardware and identification depending on use.
