Tool similar to ProjectWise that will show a projects models linking structure
Tool similar to ProjectWise that will show a projects models and the linking structure between all files, in both a report and visual form.
Tool similar to ProjectWise that will show a projects models and the linking structure between all files, in both a report and visual form. Currently users have to create a file map on a save and close sheet that is not dynamic/synced with the projects linking. So it has to be manually updated and reviewed for accuracy. This file map helps greatly for the users to get familiar with the project and for Support Members like myself to quickly understand this structure and save time troubleshooting (particularly visibility and performance issues).
